I have to calculate cross section Area to a Circler TBM Tunnel as m^2/m to Find EA and EA How can I calculate
I have E,v, diameter and thickness parameters
EA and EI*
Hi Umit,
We assume that the plate used to model the tunnel lining has a rectangular cross-section. Therefore, the section area will be equal to:
A = b x d = (1m) x d, where b is the dimension of the model in the out-of-plane direction and d is the thickness of the lining.
Conversely, the moment of inertia is equal to:
I = (1/12) x b x d^3 = (1/12) x (1m) x d^3
Answer Verified By: Ümit Arat
Thank you very much Mr Basas
