Different local axes
Hello together,
When I try to generate my mesh, I get this error:
"Cut object Polygon_1_Surface_5_1 has multiple source surfaces, but they have different local axes definitions: Polygon_1, Surface_5"
So i tried to change the lokal axes of the surface.
After some research, I found a tutorial that explains how to change the axis orientation from 'Automatic' to 'Manual'. However, it doesn't work when generating a tunnel using the 'Tunnel Designer' tool. The axes of individual surfaces cannot be adjusted. Can someone help me with this?
