I am extracting load displacement curve considering every step. But right now I am considering node corresponding to the soil.
Similarly, I want to plot the curve between two axes which will be having displacement of node on x axis and corresponding normal stress of node on y axis. I want to use the node of interface element. And I want to extract the responses stepwise only.
But when I am doing this, I am getting responses only for 3 steps as shown below:
You might be wondering why this is happening, but it's because the node in question is calculated after the analysis. I attempted to select the node before the analysis, but when selecting the node for the interfacial element, it doesn't display the pre-calculated node after the analysis.
I request bentley team to please guide me on this.
Dear Rituraj,
First, allow me to say that if you need an swift response to your support query, you should open a case following the link below: https://bentleysystems.service-now.com/csp
Now, to your question: an interface node is considered a structural node and cannot store any results if selected before the calculation. In case you need the results from the interface per step, I recommend changing the value of the phase setting of Max number of steps stored following the information here: How to setup the number of steps stored in PLAXIS Input
Here you can find more information on Selecting points for curves .
