The tunneling process demonstrated in tutorial-7 within Plaxis 3D
We used tutorial-7 in Plaxis 3D to model the tunneling. We cut the section in the y-direction to create the Figure (attached).
How can we prevent the initial settlement in the tunneling model?
Thank You in  Advance
  • Dear Nattavich,
    It's not clear what tutorial you're referring to, because the tunnel tutorial in the PLAXIS 3D manual is tutorial 5 and not tutorial 7. Also, the tunnel tutorial has only 5 calculation phases and in your graph you're referring to phases 17, 30, 40, 50 and 55.
    Finally, I would like to point out that tutorial exercises are to demonstrate functionality of the software and should NOT be used as basis for a real project.
    With kind regards,
    Dennis Waterman
Reply
  • Dear Nattavich,
    With kind regards,
    Dennis Waterman
