Hi, how can I use the Python API to model tunnels?
Hi, how can I use the Python API to model tunnels? I'm already going crazy!
If I use the process of Tunnel Designer to code and model, the code will terminate when assigning material to the tunnel plate unit, and the error is' The plate unit does not exist 'because the tunnel has not yet been generated.
If I still use the process of Tunnel Designer to code and model, but if I create a tunnel without assigning material, the code will also terminate when assigning material to the tunnel plate unit. The error is' Polycurve cannot be modified because it is generated by Tunnel Designer '.
If I create arc polycurves, then create plates for them, assign materials to the plate elements, and create interfaces, then the tunnel can be modeled successfully, but this will lead to mesh failure.
