Hello, as you can see in the attached image, I have to dig an excavation with a strut type shoring system. The problem is that the butons are bi-pods. I tried to use a central beam connected to two node-to-node to attach a sheet pile curtain to the plate. The calculation fails. Do you have a technique for modeling these shoring in several elements?
Best regards
Aurélien
I don't know .... I have never tried. That's why I said "it maybe worth a try" because I have never tried myself. I would suggest to make a separate very small model to check rather then changing your large model....in case it doesn't work either.
With kind regards.
Dennis Waterman
