I am trying to use the Python script to set my material model and properties. For example, If I try to set material properties for the user-defined Drucker-Prager model:
material1 = g_i.soilmat()material1.setproperties( "MaterialName", "1", "SoilModel", 100, "UserDLLName", "example_ivf64.dll", "UserModel", "DP", "gammaUnsat", 100, "gammasat", 105)
How to set the material properties such as "G", "nu", "Alpha", "Beta", "C"? Thanks!
Dear Kunyu,
I recommend manually creating a material using the GUI (Graphic User Interface) and then using the echo command to query the available properties. Then, they are just like the other properties you have defined (e.g., gammaUnsat).
For example:
Answer Verified By: Kunyu Yang
