<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>PLaxis 3D - Surface prescribed displacement</title><link>https://communities.bentley.com/products/geotech-analysis/f/forum/246564/plaxis-3d---surface-prescribed-displacement</link><description>Hello
 I&amp;#39;m looking for a way to assign displacement fixities perpendicular to a plane which is not perpendicular to the principal axis x, y , z. For example asign radial displacement fixities to a curved surface (tunnel, shaft..)
 Thank you
 Malcolm</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: PLaxis 3D - Surface prescribed displacement</title><link>https://communities.bentley.com/thread/769939?ContentTypeID=1</link><pubDate>Fri, 16 Jun 2023 11:38:34 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:14b04f19-9282-4290-a5bf-6f6ad9d67b67</guid><dc:creator>Vasileios Basas</dc:creator><description>&lt;p&gt;Hi Malcolm,&lt;/p&gt;
&lt;p&gt;Assigning a prescribed displacement fixity in a specific direction (i.e., radial) is unfortunately not possible. Unless you are also willing to fix the tangential direction, using the surface prescribed displacement may not work as expected.&lt;/p&gt;
&lt;p&gt;A suggestion that comes to mind is to define a set of fixed-end anchors with a high axial stiffness on that same plane. This element allows you to &amp;quot;fix&amp;quot; a point against a specific direction that you define yourself.&lt;/p&gt;
&lt;p&gt;Regardless, I think you should submit this idea to our portal: &lt;a href="https://communities.bentley.com/products/geotech-analysis/i/ideas"&gt;communities.bentley.com/.../ideas&lt;/a&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
