Hi plaxis community,
I am wondering if there is a python command to extract results from Plaxis Output for a given section.
One can create a plot of the section using:
g_o.linecrosssectionplot(g_o.Plot_1, x1, y1, x2, y2)
My next steps would be choosing the type of the result and then opening the table output, so I only get results from the section drawn.
I would like to automate these steps, but could not find suitable commands for the steps of
Tool>Table (or ctrl+T)
copy / paste the results from the table
Would it be possible to do this via python command?
or do I need to go the long way, extracting all the nodes results, separating the near-by ones and interpolating to get the value for the section?
Many thanks and kind regards,
Nataly
Hello Nataly,
I guess you are searching for the getcrosssectionresults command.
For example, in the screenshot above I use it as follows:
g_o.getcrosssectionresults(g_o.Plots[-1], g_o.Phases[-1], g_o.ResultTypes.Soil.Ux, True)
You can find more information about our commands under Help > Command reference.
Hello Stefanos,
thank you for your response. Unfortunately this command is not recognized by Plaxis in my case (see screenshots attached). Can it be due to the version of Plaxis? I am using V22.
Yes, correct.
The command was released on our first update of V22 (V22.01): PLAXIS 2D CE V22.01.00 Release notes
But you can feely update to the latest of V22, which is V22.02 if your projects allow you, to get the most of the functionality we offer:PLAXIS 2D CE V22.02.00 Release notes
I have only access to V22.00 or V23.
I installed V23, to only find out that the syntax apparently changed again and my scripts that run on V22 do not run on V23.
Questions at this point:
1. do you have a translation guide (like the one for V21 --> V22) now for V22 --> V23?
e.g.
s, g = new_server(server_address, localhostport_output, password=passwd)
s.new()
to start a new model is not working anymore and gives the following error:
raise JSONDecodeError("Expecting value", s, err.value) from None
JSONDecodeError: Expecting value
In the command manual I could not find any reference to the change in commands related to starting a new project.
2. do you plan at some point to stop changing the commands for the new Plaxis versions? It is extremely frustrating to have to re-write the scripts written for an older version, if an update is installed.
e.g. the BoundingBox command output has a new format that differs from the previous plaxis versions. I just can't see how that is a change that is essential for the software performance.
Thank you for your feedback.
With PLAXIS 2023.1 we made some changes to the materials as we dramatically improved the way we store things and to accommodate for changes in the future.
For this reason, we have introduced this page in which you can find the major changes and apply a global replacement on the material properties: Material Property changes for Python scripting
Other than that, you can always check our PLAXIS 2D Command compatibility notes page, which covers the rest of the changes that can occur from time to time as we try to have consistency in our software.
To your questions:
1. We did not change anything on this part. The error indicates some decoding issue so I am guessing something happened with the file itself. I can only suggest that you download this example code I have and compare the encoding with the one you created.boilerplate_with_SciTE.py
If you need further assistance, please feel free to create a support case: https://bentleysystems.service-now.com/csp
2. Apologies for the frustration caused. We try to improve our software to make things consistent. We are not planning any major changes to the commands and objects in the near future, however, we may make changes if we find mistakes or omissions. I guess that you can understand why we do this.These would be mentioned in the compatibility notes we release (see link above).
The BoundingBox was an attribute that was before a simple string. We have now implemented it to be an object with attributes (intrinsic properties). This means that you no longer need to parse the string to retrieve the coordinates but simply access them directly as properties:
echo Polygon_1.BoundingBox.xMax
This was a long request from multiple users and we believe that can enhance your automation scripts, too.
