Why is the acceleration time graph high in the first seconds in the outputs of dynamic analyzes?
Dear Kubilay,
This is of course something that just based on a graph we can't judge.
With kind regards,
Dennis Waterman
Of course it is, but there is no such behavior in the input earthquake acceleration-time graph.
Well, since you know that based on jus a single graph without context it can be judged why the acceleration is high I presume you also have the answer and there was no need to ask the question here.
Answer Verified By: kubilay coşkun
Although there is no increase in the acceleration-time graph, why instant increases are seen in the acceleration graph, this does not seem to be a normal behavior.
As mentioned before, just based on a graph we cannot judge whether this has a logical explanation or not.Since this seems to be specific for a project you're running, I would suggest to create a support case so that one of our support engineers can have a look at it : https://bentleysystems.service-now.com/cspWith kind regards,
thanks.
