Shear failure in Dense Sand
Hello, I've modeled a square footing with a huge point load at its center (100,000 kN) on Dense Sand in order to assess the bearing capacity of soil by locating the shear failure point from the Load-displacement curve.
Mstage vs IuI for the loading phase for a pre-cal node at the center of the footing:
After increasing the max unloading steps, it is predicted that the ultimate load should be taken where the solver finishes the calculation (point 3). However it seems that in points 1 & 2, the curve has gotten flat too, with the number of steps used at each point > the number of unloading steps in point 3, therefore why didn't the calculation stop at either of the first two points?
At which point should the ultimate pressure be taken?
Can someone explain how the unloading mechanism works in PLAXIS, and specifically at points 1 and 2?
Thanks for sharing your thoughts!
  • Dear Mr. Dennis,
    Would you recommend to always increase Nmax to a large number, e.g. 1000 for such analysis? This way it should always yield a flattened part, however, the ultimate load will be depending on CSP alone in that case.
    Your help and assistance is much appreciated!
    Mohamad
  • Dear Mohamad,
    The Nmax doesn't determine the ultimate load, it only detemines when PLAXIS will stop trying to increase the load. Hence, if you really reached the ultimate load a higher Nmax will only lead to a larger horizontal part, but it will be the same ultimate load as for a lower Nmax.
    Your graph doesn't look like an ultimate load is reached, but more like there is convergence problem due to the mesh or the model making the calculation stop. But as I mentioned before, graphs may not tell the whole story - based on other results like plots of displacement increments, shear strain increments, plastic points and/or mobilised shear it may become clearer whether the ultimate load has been reached (hence, there is failure or not). I would start checking those results rather than being very fixated on a single graph.
    With kind regards,
    Dennis Waterman
