FEM Modelling
Good day members. I have a doubt and I would like to have this solved.
So, what is the minimum distance between the model and the boundaries when modeling with any FEM software, do you have any referencethat may have some basic theories about this topic?
A small model may have any influence on the output results? How? Any reference?
Thanks in advance.
  • Remembering that the main objective is to model piled foundations subjected to axial loads.
  • Dear Cristina,
    It depends a bit on the type of analysis  you're doing, particularly seismic analysis needs far larger models than static analyis.
    But as a rule of thumb if you look at the construction zone D x W (depth, width of an excavation, embankment, foundation etc) and you take the largest dimension of that area, then use a model with in all directions at least 3x times that largest dimension. So for an embankment that largest dimension is usually the width W, so use 3*W on either side of the embankment ánd also below the embankment.
    Under specific conditions a smaller model may be good enough, but there is not really such a thing as a too large model, but there can be a too small model.
    If the model is too small it may underestimate deformations and overestimate factor of safety and/or failure load.
    The idea is that a boundary is so far away from the construction zone that stresses close to the boundary remain (almost) unchanged from the initial stresses during the construction. The lower boundary may experience a stress increase that is max 10% of the applied load.
    With kind regards,
    Dennis Waterman
    Answer Verified By: Cristina Nhatuve
  • Dear  Dennis, thank you for your quick response. It will be helpful. So, you do you have any reference that I can use to cite in my text?
  • Hi Cristina,
    We have gathered a lot of this information as rules of thumb in a presentation. In this presentation we refer to the following literature, so maybe you want to use them too:
    Potts D.M., Zdravkovic L. (2001). Finite element analysis in geotechnical engineering – Application. Thomas Telford, London.
    Meiβner H. (2002). BaugrubenEmpfehlungen des Arbeitskreises 1.6 “Numerik in der Geotechnik”, Abschnitt 3, Geotechnik 25, 44-46.
    Schweiger H.F. (2002). Musterlösung und Parameterstudie für dreifach verankerte Baugrube,
    Geotechnik 25, 101-109.
    Ruse N.M. (2003). Räumliche Betrachtung der Standsicherheit der Ortsbrust beim Tunnelvortrieb.
    PhD thesis. Institut für Geotechnik. Universität Stuttgart.
    Vermeer P.A., Wehnert M. (2005). Beispiele von FE-Anwendungen – Man lernt nie aus. In: FEM in der Geotechnik (ed. Grabe et.al.). Technische Universität Hamburg-Harburg.
    Brinkgreve R.B.J, Bakker K.J., Bonnier P.G. (2006). The relevance of small-strain stiffness in numerical simulation of excavation and tunnelling projects. In: NUMGE 2006 (ed. Schweiger). Taylor & Francis, London. 133-139.
    With kind regards,
    Dennis Waterman
