Dear all,
When a circular lining is modeled using a solid element, whether the bending moment and axial force of the lining can only be obtained by establishing a virtual plate. Can you add a function to extract the bending moment of the solid element lining ? At present, it seems that only the internal force of the solid pile can be extracted .
Thank you a lot,
Best regards.
This functionality already exists for several years. In 2D Output it's called "Structural forces in volume plates" and in 3D Output it's called "Structural forces in volume piles". The option is under the "Tools" menu.
With kind regards,
Dennis Waterman
Answer Verified By: xin Fang
In my tests, this function does not seem to work for hollow cylinders made of solid units (such as pipe piles、linings..), only for solid cylinders made of solid units (such as solid piles).
