Define strength parameters as functions of strains.
Hi, is it possible to define a strength parameter (such as cohesion and friction angle) as a function of the deviatoric strains?
There are two acceptable options:
1. The parameters are updated along with the strains during the analyses.
2. The parameters are unchanged during the whole analysis where strains develop, then we update the parameters in each node, and then following analyses are conducted with the new parameters kept constant again.
For the second option, there should be a way to assign a parameter value to each node. Is this possible in plaxis?
Solutions that require scripting are welcome!
Parents Reply Children
