Strange behavior or pore water pressure
Hello, I'm trying to model an excavation in an axisymmetric 2D model.
Water pressure was defined in a particular way at the initial phase where the bottom soil layer was set to dry and the layer just above it was set to "interpolate", resulting in a diagram that is in accordance with what's in my mind:
however in the following phase where only the surface loads are activated (without changing a single thing in the model), the diagram becomes different. It was noticed there's a "jump" in the water pressure at the base of each layer as you can see in the below figure.
Can someone please give an explanation for this jump and what could be the thing leading to that change?
Note that only Phreatic is used as a pore pressure calculation type.
Thanks in advance!
