Hi all,
Can anyone tell how to draw the water table for this following cases using points?
Thanks.
Hello Nitharshan,
I am assuming this is a top view of your water table.
How can it be physically possible to have a gap in a water table? Usually, this is because of an external way to remove water from the system (pumps, wells, etc.).
Therefore, in PLAXIS, to simulate this you can use (created) different water tables for the excavation area or assign different WaterConditions to the volumes that belong to this excavation.
Note that depending on what you are doing in the Staged construction you will need to choose from Phreatic or Steady state groundwater flow pore pressure calculation type or Fully coupled flow-deformation analysis to properly simulate the pore pressure distribution.
In general, you should not try to draw a water table with a gap as it would incorrectly define the boundary conditions in any model.
Dear Mr. Stenfanos,
Thanks for the reply and it is the top view of the excavation area (Blue colour is the soil volume and white colour is the excavation area as shown below). So I need to know how to input the points in Plaxis 3D to draw the water table for this excavation area with 2m depth (let's say).
Noted, thanks.
Dear Mr. Stefanos,
I created the water table as shown below but in output water pressure didn't come as what I defined. What is the reason for that (Any error in the software installation?)?
but when provided volume dry option, water table came correctly.
I am not sure if there is an issue other than visualisation accuracy.
Have you checked the pore pressure distribution or the groundwater head value? This should help you identify if everything is okay.
By making the excavation Dry, you force the water level condition inside the excavation to ignore what you have drawn, which makes sense.
By the way, I am not sure if you are using a Phreatic pore pressure calculation type, but this is what we call a "z-shaped" water level which is to be avoided.
We have mentioned this in our various webinars, which can help you with your PLAXIS model, too:
Thanks for the reply and water condition was provided as phreatic and distribution also not correct. Anyhow I will check the webinars you have shared.
I have one question about the excavation dry option.
Question =>
If we have embedded depth then we can use cluster dry (2D) and volume dry (3D) and then interpolate the water pressure for the soil inside the embedded depth to avoid the sudden increase in the water pressure and pass the analysis.
But if the retaining system doesn't have the embedded depth like shaft excavation or open cut slope, then providing dry option will make the soil fail (consider cohesionless soil) as the sudden change in the pore water pressure at the excavated area and no shear strength of the soil. How can we avoid this when using cluster dry or volume dry option?
Hello again,
The interpolate pore pressures work as you show, but it should be used when it fits the soil conditions and behaviour. I can see that you extend the zone of interpolation of pore pressures up to the exact depth of the walls, but then you would have an odd transition at the tip of the wall. That should also not be the case as this may cause inaccurate results for the structure.
In all cases, try to consider what would happen in reality, if you try to have a different water condition inside the excavation, how far do you expect this to extend deeper? Then, you should be able to understand the impact of the extent of the interpolate pore pressures zone and when the global condition should be used.
For the particular case where there is no embedded depth, I would say that this goes into the design area, which I cannot really comment. I would consider that if the difference in pore pressure is that high, probably you need to do something about it (counter support?). Again consider how it would be in reality; if you remove the water from the excavation (how do you do that? wells?) wouldn't the soil exactly at the excavation bottom also show a reduction of pore pressures (as the head reaches the same elevation)?
In any case, I leave that up to the designer as this is a situation that you have to evaluate and act accordingly. Note that PLAXIS gives the tools, but cannot do the design for you. There are decisions to be made by the engineer on how to prevent unwanted situations, provided that the simulation is done in a manner that models reality as closely as possible.
Thanks for the reply.
Dear Geo community members,
Any reply to my question (because they expect to design the system in full water table even though that is not practical)?
