pref value from in situ testing
Could someone help me how to determine the pref value for the HS (or HSS) material model when the stiffness parameters (E50, Eoed, Eur) are determined based on in situ borehole pressuremeter test results? Should the pref value then be the value of applied pressure for a certain loading cycle of the test?
Many thanks in advance!
