what would the effect of suction in intial stage, excavation stage and loading stage? Should i uncheck or check that.
Depends on what type of analysis (Plastic, fully coupled) you are doing and what do want to achieve like do you want to study the effects of suction in the short or long term? Have you defined the SWCC of the soil or are you relying on the default unsaturated parameters of PLAXIS?Also where is the water table located at?
I have clayey silt followed by sand till 20.0m then sandy soil till 75.0m and WT is found at 20.0m. I'm studying only settlements of raft under undrained case. And for SWCC am using the default values. I have hardening soil model and undrained A for all the soil layers.
I clearly understood now. Thank you.
I have one more query can i apply hardening soil model for clayey silt, sand and clayey sands. Since undrained condition gives my immediate settlements. Can I use the undrained A condition for all the soil layers which I have mentioned above.
Settlements are less when I ignored suction. Which is not the way you said. Can you please explain.
My colleague didn't mention settlements, so your statemen "that is not the way you said" is not correct.
He mentioned that when having suction effective stresses are higher. And higher effective stresses generally give higher settlements.With kind regards,
Dennis Waterman
Answer Verified By: Faseel Khan
Thank you for your clarification.
Can you please explain this.
