Hi, I have Plaxis 2D/ 3D Advanced - however I need to change it to the Ultimate. Can you please advise?
Hi Ilkin,
You can change the tier from Help/ Licence configuration.
Note that this process is also explained here: I use PLAXIS and it says I do not have the proper entitlements
By the way, if you do not own PLAXIS 2D/3D Ultimate, please reach out to our support: https://bentleysystems.service-now.com/csp?id=csm_sc_cat_item&sys_id=f0e349131b5081103eeeeb53604bcb42
