Equivalent length for FE anchor and N2N anchor
Hey!
I've always been a bit confused about how to set the equivalent length of FE and N2N anchors.
What I understand by far is that a FE anchor usually used when it's symmetrical excavation and the equivalent length is half of the excavation length. While a N2N anchor can be used to as an alternative when the structure is supported in multiple directions and the equivalent length of the N2N anchor needs to be adjusted accordingly. Is this correct?
Does it mean, if I have a non-symmetrical excavation, for example in the figure below, I should use N2N anchor instead of FE anchor (or is it possible to use FE anchor as well)? And for this N2N anchor, I don't need to consider anything regarding equivalent length?
Thanks a lot for help!
  • Dear Xuyan Liu,
    I'm a bit puzzled by your question as you speak over the equivalent length of a Node-to-Node anchor .... but Node-to-Node anchors don't have an equivalent length, they have a real length (which is the length you  draw).  The reason that we have to specify the equivalent length for a Fixed-end anchor is because we do no draw the real anchor length, we only specify a spring and thus the user must specify what real length that spring represents. Since for a Fixed-end anchor the end point that is not connected to our model is fully fixed (hence the name Fixed-end anchor) we have to specify the real length from our structure to a point where we can consider our real anchor to behave like fully fixed - and that point is the axis of symmetry, not the other side of the excavation. Therefore the equivalent length should be half the excavation width. This also explains why we call it "equivalent length" and not "real length", if we would call it "real length" you may think you have to specify the full excavation width, which would not be correct.
    With kind regards,
    Dennis Waterman
  • Hey Dennis,
    Yes, I was myself confused by equivalent length, because they mentioned something like when replace FE by N2N anchor, one should be careful about stiffness etc. But what you've explained here answers my confusion and I do not need to consider anything regarding equivalent length when I use the model I paste here. Thanks a lot!
Reply Children
