Modelling Hydrodynamic forces in Plaxis
HI
I am looking to model hydrodynamic forces in a slender cofferdam dynamic analysis.
Rather than use an added mass approach, I was considering running the model and extracting the +/- xdir  velocities at various points in the structure. I can then use this to calculate the additional or reduced hydrodynamic forces at each time step (using the calculated force per time step as the load multiplier) such that the hydrodynamic effect of the structure moving into a body of water is captured by an increased opposing pressure acting as resistance (damping the system), and moving away from the water body results in a reduced pressure.
Has anybody tried this, or can suggest improvements to this proposal? Are there any obvious pitfalls that I am not seeing. (note, this is purely for academic purposes, not a real-world problem).
Scot
