hello dear, Micha van der Sloot
i just want to use the barcelona basic model /as a user defined soil model/ in the plaxis 3D v 2013. so if you have the programing/coding/ of this soil model please help me.
Dear Tekial Tesfay,
Thanks for the question, note that in order to use User Defined Soil models, you must make sure you have the Geotechnical SELECT Entitlement activated (formerly VIP), Note you are using an older version of PLAXIS, in which this is not fully supported since the Geotechnical SELECT Entitlements only work for the latest versions of PLAXIS. So please update to a later version of PLAXIS to use this.
Next to this, you should note that the Barcelona Basic model is not generally available at the moment, see also our WIKI page: https://communities.bentley.com/products/geotechnical1/w/wiki/46109/udsm---barcelona-basic-model
If you need access to this, please follow the contact link on the page and submit a service request with the relevant details of your licence (e.g. company name, intended use, etc)
Kind regards,
Micha
dear Micha .
i havn't the latest version, if you have pleas try to atach to my email tekialtesfay54@gmail.com
