dear, Micha van der Sloot
is it possible to use plaxis 3D v 2013 for the user defined soil model Barcelona basic model.
Hi Tekial
I am afraid that the Barcelona Basic Model is not available for PLAXIs 3D 2013. Next to that, it would also require a PLAXIS-VIP subscription/licence for that version, which is not available any more.
The only way would be to move to the PLAXIS 3D CONNECT Edition V20 to allow the Geotechnical Select Entitlements (this is formerly known as PLAXIS VIP)
Kind regards,
Micha
Dear Micha.
Thank you for your quick response.
can you share me the link for PLAXIS 3D CONNECT Edition V20
Kindly Regards.
Sure, all PLAXIS downloads are available via: https://communities.bentley.com/products/geotechnical1/w/wiki/42503/plaxis-software-downloads
Direct download link is here: https://softwaredownloads.bentley.com/en/ProductDetails/2804
Thank you again more.
and again can you share me the plaxis DLL file for BBM.
Heartily Regards.
Dear Tekial
For this, you would need to create a Service Request here so it can be properly processed. Note that we only supply this model to Bentley SELECT users, since you can only use the DLL when you have the Geotechnical SELECT Entitlements (GSE). If you can use the PLAXIS 3D CONNECT Edition V20 version, your Bentley account can also be used to submit a service request.Link: apps.bentley.com/.../ProductSupport
