Need help working from home with your Bentley software? We're here to help - click here
SIG Virtual Workshop: Geotechnical Analysis - Using SoilVision SVSLOPE to Determine the Factor of Safety
Geotechnical Analysis Special Interest Group: Using SoilVision SVSLOPE to Determine the Factor of Safety
Host: Micha van der Sloot, Technical Support Manager, Bentley Systems, Inc.
Presenter: Marina Trevizolli, Senior Application Engineer, Bentley Systems, Inc.
Date/Time: April 14, 2020 at 04:00 P.M. CEST
Register Now!
Slope Stability analysis using the Limit Equilibrium Method is applied worldwide to obtain a factor of safety. With the SoilVision solution, engineers can assess critical slip failure mechanisms in 2D/3D through a deterministic and probabilistic approach. This Geotechnical Analysis Special Group virtual workshop guides engineers about concepts and methods available in SVSLOPE for determining the factor of safety.
This one-hour session works within SoilVision CONNECT Edition, Version 10 and includes a technical presentation as well as time to share questions. Topics include:
  • Assessing a critical factor of safety in SVSLOPE
  • Different search methods and their application in 2D/3D
  • Analyzing critical slip failure shape mechanism
The Geotechnical Analysis SIG is open to all Bentley users, so invite your colleagues!
Geotechnical Analysis SIGs – complimentary virtual workshops to keep you working optimally!
