Hello sir,
I put all my parameters for Mohr-Coulom and I want to know when I change to the Hss model I found Eur value automatically is the true value of Eur or not and Eur = E in MC or not?
Is there are any relationship between G0 ref and E50 or Eur?
Dear Ashraf,
The difference here is the value for the Poisson's ratio being used each time by the constitutive model.
To explain what happens behind the stage here:
If you use a Poisson's ratio of 0.2 you will not see any difference when switching from a MC to a HS material.
In general, I would strongly advise you to check the values applied as different properties rely on different parameters for each constitutive model, making the conversion back and forth less straightforward.
I hope that this is clear now.
Answer Verified By: Ashraf Aljarmouzi
THANK YOU VERY MUCH.
