I'd like to simulation the pile's expansion by volume strain .However ,something wrong when I set a cube (1m*1m*m) εyy=60%.The consequece of Uy is not 0.6m but 0.43m. So I 'd like to konw what's the promblem of this phenomenon. I expresss my thanks to the respondents !
Dear Yi Lu,
I think that the following article can explain the reason why you do not see the exact volumetric strain you provide:
https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45993/how-does-the-option-volumetric-strain-work
Answer Verified By: Yi Lu
Thanks for your reply!
You are welcome!
Dear Mr. Stefanos,
Can't be provided volumetric strain uniform to certain depth we considered? because volumetric strain effect varies with depth (eyy).
Thanks.
Dear Nitha,
Currently, there is no increment value that is considered in the volumetric strain feature.
