Dear, I am doing a 3D model with an irregular surface, I would like how I can put an irregular groundwater surfaces in my dam. Thank you.
Dear Juan Manuel,
A water level is defined in Flow conditions as a surface. You can find a similar question in the following post:https://communities.bentley.com/products/geotech-analysis/f/plaxis-soilvision-forum/199985/how-to-define-complex-ground-water-table-contour-in-plaxis-3d
In short, the simplest way is to use the command line with the coordinates of the water level (parentheses are optional). For example:
waterlevel (0 0 3) (2 0 2) (5 0 2) (7 0 1.5) (8 0 1.5) (8 12 1.5) (7 12 1.5) (5 12 2) (2 12 2) (0 12 3)
Thank you.
