Hi Plaxis support,
Is there any plaxis commands to open table format of a plate result (as shown in table below) and copy it to clipboard?
Cheers,Vuthy
Dear Vuthy,
In PLAXIS Output the results are stored in specific blocks. The graphic interface of the Output program nicely gathers all the information into a table for the user's convenience.
Via the command line, the way to extract the results, among others, is using the command getresults.
Please find examples in the links below:
By running the getresults command for each of the ResultTypes you can collect the result values as shown in the tables.
With Python you can also copy data to the clipboard, however, for that you need to research online as we do not offer a specific solution for that.
