Hello Iam a BSc student i work on plaxis 3d how i could make a circular soil sample instead of rectangular
Dear Hamid Ali,
You can ignore Soil mode and create cylinder in Structure mode.
For this we can use cylinder command (please, see Command reference in Help menu):
or polycurve + extrude options:
In both cases we should consider the boundary conditions of cylinder outer surface. By default it is not fixed, so it is recommended to create Surface prescribed displacements:
The SurfaceDisplacement conditions depends on your tasks. For me the most common variant is:
I hope this helps.
Cylinder option and Polycurve+Extrude variant give you volume.
Therefore we can assign material to this volume as usual: via right click menu, in Selection explorer or from Material sets.
