Dear Sir/Mdm,
I would like to know if there is a way to save a PLAXIS file (that has been calculated) as a file with only input information. As it is a 3D PLAXIS file that I am working on, the output results occupy alot of space. I hope to just save the file with only the input portion. May I know if it is possible? Thank you very much!
Dear Wang Haode,
I can suggest you two variants.
1. Pack Project
In menu File you can use Pack project option for project archiving. In this option you can save the archive with geometry only (even without Mesh):
Or you can choose what do you want to save: Mesh, Phases, Results.
More information about this option you can find in this video.
2. Examine commands
In menu Expert you can use Examine commands option.
This option allows to filter command list for whole project, save eg. only geometry commands and then repeat (run) all commands via Run commands option:
More information about this option you can find in this topic and in this video.
Hope it helps you.
Dear Wang,
I would recommend using the Pack Project facility as Rushan suggested.
