hi sir:I have several questions about the "SIG Workshop: Geotechnical Analysis – PLAXIS Calculation Optimizations" lesson.The lesson shows: Stiffness changes are applied at the beginning of phase and unbalance is applied gradually during phase, change of stiffness without change of load has no effect.My question is : 1.When I use a node-to-node anchor with prestress force at a phase, when the anchor element is applied? when the prestress force is applied? beginning of phase or applied gradually during phase?2.When I numerical a deep excavation, the first phase is excavation (deactivate soil element ) and the second phase is to install the slab (use activate plate element with vertical deformation fixed) . when the slab (plate element) is applied? beginning of phase or applied gradually during phase?
thank you
Hi Sheng-Hsien Wang,
For some reference on stiffness changes, please see: https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45962/reduction-of-stiffness-does-not-lead-to-a-change-in-displacements
To answer your questions:
Answer Verified By: Sheng-Hsien Wang
