I' m new using 2D SVSLOPE. I'm trying to use the "add/remove couppling" option in 2D SVSLOPE to add a SVFlUX analysis, but when I try to run the SVFLUX model an error message appears (see the image below).
Thanks in advance,
Viviana
The error message appears to be related to FLEXPDE which is the solver used to solve the partial differential equations. The FlexPDE solver needs to be downloaded and installed separately as it is a third-party solver.
If you have a FlexPDE license available to you, you must apply that license directly in the FlexPDE solver interface under the Help > Register menu.
https://www.pdesolutions.com/sdmenu7.html
SOILVISION will look for it in the default directory C:\program Files\FlexPDE7\FlexPDE7.exe. You could install it somewhere else and should then specify the path in the Global Settings dialog.
Answer Verified By: Viviana Ramirez
