Hi all,
I little bit confused about "Phreatic" and "Steady state ground flow" options after referring the manual also. Anyone please explain briefly in a easily understandable way which will helps me alot.
Thanks.
Dear Nitha,
Please check the on-demand videos for PLAXIS + PlaxFlow: Running a Groundwater Flow Analysis and PLAXIS CONNECT Edition: Excavation Dewatering and Common Pitfalls.
Our Reference manual also has a detailed explanation on this topic. I would also recommend you check (+) PLAXIS 2D Tutorial 03: Dry excavation using a tie back wall - PLAXIS | SOILVISION Wiki - PLAXIS | SOILVISION - Bentley Communities as a great example and may test using the different options to see the differences, too, that is better than any explanation we put on "paper".
Dear Mr. Stefanos,
