What is the best failure model to simulate the jet grouting material around the pile head subjected to lateral load in PLAXIS 3D?
In the literature, some of them use linear elastic and others used Mohr-Coulomb failure criteria.
Ghiath
Dear Ghiath,
Note that the linear elastic model has no failure criterion included, therefore it will not fail at any applied load. With Mohr-Coulomb that includes the known failure envelope, the material can be simulated. Apart from that, you can use any advanced material model including the Concrete model to describe in more detail the behaviour you have. As in any other case, selecting the best constitutive model for each case depends on the geotechnical engineer and the data available to best describe the behaviour of the material.
Dear Stefanos,
Thank you for your reply,
I am wondering if you have some references under your hand or just refer to some you may know to help me simulating Jet Grouting materials.
Thank you again for your cooperation,
On our Wiki pages, we do not have any references for modelling jet grouting. I would recommend searching on literature.
