Hi all.
Im assigning material for HS model based on literature value but this error came, what is the problem?
Please reply ASAP which will means alot.
Thanks.
Dear Nitha,
The error is for K0NC, which is the K0 for normally consolidated state, so please make sure not to confuse it with a K0 value.
Typically the K0NC = 1 - sin(φ).
If you still cannot find the reason for this error, please submit a service request.
Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
i found that because i didnt provide konc for that model.
hi Nitha NN,
Can you please elaborate how you resolve the problem. ?
I am having the same problem, kindly specify the list of parameters as well.
thank you,
Best Regards
Gullnaz Shahzadi
Dear Shahzadi,
When you provide the stiffness parameters , konc (ko value @ normally consolidated) is there zero (as shown below), so you need to type the value for it otherwise error will come.
I am giving the values but still getting an error
Invalid material "---" Material "----" is invalid. Regardless of whether this material is actually used, the problem should be fixed before calculations are performed.
