Hi all,
I am trying to use Python to control PLAXIS and would like to retrieve material properties from PLAXIS so that they can be automatically updated accordingly.
Does anybody know where can find the files contain all the properties in the PLAXIS project? Or have experience in how to do that?
Kevin
Hi Micha,
Thanks for your information and I played a bit with them. Some of the command such as "Changing the material colour using Python scripting" or "Access to Staged Construction settings using Python" works well, but when I tried "How to get a load - displacement curve using Scripting interface", by copying the commands it turns out following:
Traceback (most recent call last): File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1\python\lib\site-packages\plxscripting\requests\packages\urllib3\connectionpool.py", line 480, in urlopen body=body, headers=headers) File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1\python\lib\site-packages\plxscripting\requests\packages\urllib3\connectionpool.py", line 285, in _make_request conn.request(method, url, **httplib_request_kw) File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\client.py", line 1244, in request File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\client.py", line 1290, in _send_request File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\client.py", line 1239, in endheaders File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\client.py", line 1026, in _send_output File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\client.py", line 966, in send File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1\python\lib\site-packages\plxscripting\requests\packages\urllib3\connection.py", line 88, in connect conn = self._new_conn() File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1\python\lib\site-packages\plxscripting\requests\packages\urllib3\connection.py", line 70, in _new_conn self.source_address, File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\socket.py", line 727, in create_connection File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\socket.py", line 716, in create_connectionConnectionRefusedError: [WinError 10061]
Do you have any recommendations?
I am using the example "Settlement of a circular footing on sand" and the code for load displacement curve as follows:
# # change the colour of the Given material:# setMaterialColourRGB(soilmat, *RGB)g_i.LineLoad_1_1.qy_start[g_i.Phase_1]# creating the function that will retrieve# the values later in the scriptdef getphasevalue(plxobject, phase): return plxobject[phase].valueimport mathdef create_phases_name_map(phases): result = {} for phase in phases[:]: result[phase.Name.value] = phase return resultdef get_table_qactive_vs_displacement(filename, phases_i): # initial data for eventual table columns col_step = ["Step"] col_sum_mstage = ["SumMStage"] col_phases = ["Phase"] col_utot = ["Utot"] col_qactive = ["qactive [kN/m2]"] col_load = ["Load [kN]"] # load for axisymmetric models radius = 1 area = math.pi * radius ** 2 phasesmap_o = create_phases_name_map(g_o.Phases) # look into all phases, all steps: loadfeature_i = g_i.LineLoad_1_1 for phase_i in phases_i: qphase_end = getphasevalue(loadfeature_i.qy_start, phase_i) # check if previous phase has a Line Load # that is deactivated (then load=0) if loadfeature_i.Active[phase_i.PreviousPhase]: qphase_start = loadfeature_i.qy_start[phase_i.PreviousPhase] else: qphase_start = 0 phase_o = phasesmap_o[phase_i.Name.value] for step in phase_o.Steps: sumMstage = step.Reached.SumMstage.value col_phases.append(phase_o.Name.value) col_step.append(int(step.Name.value.replace("Step_", ""))) col_utot.append(g_o.getcurveresults(g_o.Nodes[0], step, g_o.ResultTypes.Soil.Utot)) col_sum_mstage.append(sumMstage) col_qactive.append(-qphase_start + sumMstage * (-qphase_end + qphase_start)) col_load.append(col_qactive[-1] * area) print(phase_i) if filename is not None: with open(filename,"w") as file: for results in zip(col_phases, col_step, col_utot, col_qactive, col_load): print('\t'.join(["{}".format(i) for i in results]), file=file)get_table_qactive_vs_displacement(filename = r'D:\dataload_displ_data.txt', phases_i = [ g_i.Phase_1 ] )
Hi Kevin,
In the feedback/error you got from running the script, I read this near the end:
Kevin C said:File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\socket.py", line 727, in create_connection File "D:\obj\windows-release\37amd64_Release\msi_python\zip_amd64\socket.py", line 716, in create_connectionConnectionRefusedError: [WinError 10061]
It seems that the connection is refused. Is PLAXIS launched with the correct remote scripting settings as was set in your script using the proper port and password?If you really get stuck in getting this to work, please submit a service request and upload the relevant file there: https://apps.bentley.com/srmanager/ProductSupport
Thank you for your comments. What I just found was I put a "g_i" to a "g_o" by mistake. The code now runs perfectly.
Best,
Great is now solved. Thanks for the feedback!
