Hello everyone.
I am doing an analysis on a gravity wall. I was wondering if it is possible to implement it in Plaxis 2D and if yes how?
Should I first create the geometry of the wall and then use the material assets to define the parameters?
Dear Nikolaos,
You should create the main soil stratigraphy in Soil model, add any polygons that define the gravity wall in Structures mode, and when in Staged construction assign the corresponding material data set to the relevant phase that your gravity wall is built.
Answer Verified By: Nikolaos Antoniadis
