Hi all,
Please explain the these lines briefly by providing example as i couldn't get.
In the below screenshot what is the meaning of default for embedded beam row connection with plate and soil because when i draw the embedded beam row it shows as rigid
Why this statement is highlighted? what happened if this element connect to the interface (not like this , for knowledge purposes).
and finally what is the meaning of this?
Dear Nitha,
I will comment on each part in the same order.
Dear Mr. Stefanos,
Thanks for the explanations and why if we provided the embedded beam row in soil polygon without any plate, the shaft resistance is ignored?
With that i'm eager in stiffness factor clarification.
01. Please tell how this factor comes?
02. For axial and base stiffness resistance, Gsoil is used as shear failure can occur but what is the reason for using Gsoil in the lateral stiffness calculation ?
Thanks.
Any help please
If the embedded beam is extended inside the volume (modelled as linear elastic) the purpose is achieved in making it rigidly connected. The extension is not based on reality but rather a "trick" to achieve a proper connection with the concrete. If you add the plate, then the connection is also ensured so either way will work fine.
The factors that you mention are the Interface Stiffness Factors of the embedded beam row elements in PLAXIS 2D. Note that the default values are for bored piles which are loaded statically in the axial direction and the surrounding soil is modelled with Hardening Soil with small-strain stiffness. You may need to calibrate these parameters to fit your case.
The Gsoil is considered in every case just like in the typical application of the interfaces on a plate element. For more information, you may need to check our Materials Models manual.
Noted with thanks.
