Hello everyone,I am currently studying a double lining tunnel problem on Plaxis 2D and i would like to present to you a case. I need to present the results of structural forces calculation in specific points on my lining and i can't seem to find a way of getting around this problem. Any input on this would be highly apreciated.Regards,
Dear Islam Lotfi Hadj-Arab,
When you use the Structure forces in volume plates functionality, you can check the results in the table. The tabular results are available in the top toolbar (next to when you change the phase in Output).
Dear sir,Thank you for your answer, but i am interested in specific points that are not automatically generated buy the meshing. The study that i am conducting requires that i compare specific points with an other method. Thus, i am looking for a way to get the information on the specific point list that i have.
Thank you again,Regards.
Dear Stephanos,I have thought of this alternative, but i have a rather long list of points (around 60-70). Do you happen to know a method for creating them all in a single shot ?
Thank you again for your help.Regards
Dear Islam,
The point command supports multiple coordinates and will create multiple points in one go. So, all you need to do is to write a long command like this:
point 0 0 10 0 15 0 20 0OR optionallypoint (0 0) (10 0) (15 0) (20 0)
Note that our command runner access copied data from any spreadsheet, too: https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45856/practical-use-of-the-commands-runner-pile-field
With Python this can be done if the point coordinates are in a list:
point_coordinates = [0, 0, 10, 0, 15, 0, 20, 0]g_i.point(*point_coordinates)
Dear sir,Thank you so much for your answer, I'll be sure to try it out as soon as possible. Finally, do you know a way to extract only the results i want from the table and not the whol nodes ?Regards,
What table are you referring to? The table with results we have in PLAXIS always includes all nodes. This is the same as running the getresults command.
If you are interested in the selected points, then you can use the getcurveresults command. Please check our Command reference for more information.
Dear Stephanos,
Yes i was reffering to the table of results in Plaxis. I was looking to a way to filter out unnecessary points but nevermind.Thanks again for your help.
