Hello;
Actually, i have been wondering that;I ge the results for hgt like this :
Hgt=g_o.getresults(g_o.Phases[-1], g_o.ResultTypes.Soil.HydraulicGradientTot, 'node')
I could read the results on hgt but i could not set any result in the list like ;Hgt[100]=-1 on any other var type etc. This gave an error.Is there a method or a function to set the hgt result or did i miss something simple?
Thank youEmre Dumlu
HiThe goal of PLAXIS Output is to read the results from the calculation. As such, setting values is not a common workflow.
Is there something specific you would like to do here?
