Hi, does anyone found a way of mirroring objects?
As I've made a whole model, made calcualtions and only after that found that it's mirrored. It's mirrored because I imported geometry from Autocad and swaped axes from x to y. There is a problem with exporting geometry and there were made a lot of changes in Plaxis, so reimporting and remodeling will take more than a couple of days.
If anyone found a way of doing it with in Plaxis either with standard funcionality or with Python for example - it would be great. (I need to swap x and y coordinates for every object, for lines, points, planes and soils it can be done manually, but will take long hours, but for volumes it's not that simple)
How the geometry is within Plaxis and how it should be in Autocad.
Thanks!
Dear Александр,
You can try the rotate over the X-axis option. Check my screenshot below (in my case it is over Y-axis):
Dear Alexander,
I want to offer you a non-standard way that might make it a little easier. You can export the entire geometry to DXF (menu File → Export geometry), quickly fix the error in AutoCAD and import everything into PLAXIS again. Yes, properties and materials will be lost, but you will have a finished geometry.
Уважаемый Александр,
Если у вас остались вопросы на русском языке, вы можете направить их на почту plaxis@nipinfor.ru. Мы постараемся помочь. Спасибо.
Dear Stefanos, thank you for your answer!
But for this case rotating won't help. Or the top and the bottom of the tunnel will change their positions because it's inclined. But for other cases this solution could help.
Dear Rushan, thank you.
In this case it worked, but earlier there were problems.
That there is the volume, it is meshing, everything is fine.
You export and import without any changes and the problems occur.
Or sometimes the geometry can't be exported.
This problem occured many times while I was making this model especially while importing the volume from the Autocad.
But right now I checked and everything is fine. Thank you for the solution!
Уважаемый Рушан,
Направлял вам и вашим коллегам лично письма. В следующий раз буду на предоставленную вами почту. Спасибо.
Thank you for the feedback. I'm glad the solution helped.
Благодарю вас за информацию. Если вдруг ответа долго нет (к сожалению, иногда бывают глюки с почтой), то можно написать мне в Телеграм. Спасибо.
