Dear Plaxis Support
When I model a discontinued pile wall, I enter the stiffness (axial and flexural) as the stiffness of the element divided by the distance, "s", between two of them. After the analysis I got the internal forces (bending moments, normal and shear forces) "per meter width". For pile design, should these forces multiply by the distance between them "s" or by its diameter "d"? or the values from output can be used directly for design.
I hope you can help me with this question.
Thanks for your support.
Ramón S.
Many thanks for your answer Dennis.
