I am investigating the failure mechanism of the belled pile embedded in geogrid-reinforced sand under uplift load in PLAXIS 3D current version. However, I can not run the geogrid in the model I have installed. In my previous work, I investigated the uplift behavior of the anchor plate embedded in the geogrid-reinforced soil in PLAXIS 3D TUNNEL version and saw the effect of the geogrid in both capacity and failure mechanism. However, in the new version of the software, I could not operate the geogrid under the uplift load although I'm doing updated mesh. I have reviewed the previous posts/papers about geogrid in the forum and based on the studies, I tried to make the geogrid anisotropic and set the GA to zero, but still, the result did not change. Why can't I run geogrid on uplift load?
Dear Buse,
I read about a very specific project and configuration which makes it very difficult for us to identify why this does not give the expected behaviour.
In order to be able to assist you with your project and identify the reason for the problem you experience, please submit a service request. Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
Answer Verified By: Buse Emirler
Dear S. Papavasileiou,
I shared the analysis file via Bentley's Sharefile service. The service showed the message "uploaded".
But I have not received email yet such as "the analysis file has been reached etc".
Is there any problem about the process of file upload?
As I mentioned above, you will first need to submit a service request.
I do not know where your file is uploaded but if you reach out to us via the service request manager then we can send you a direct link where you can upload your project.
I have submitted a service request. Its number is 7001360724. After, it was shared a link (Bentley's Sharefile) and I have uploaded my packed project.
Hello Buse,
I can see that one of our support engineers have already picked it up. That is the fastest way to get a response to your specific project. More in the service request now...
