Hello, I have a gINT library set up by someone else, which we use for Geotechnical logs of wells, borings, etc. I need to customize the width of some leader lines for my 'pointer' in gINT. The library is set up so that you go into DATA DESIGN> Lookup Lists> Pointer (this is the table I need to modify). Now I'm able to add a new pointer here, but can't figure out where the properties are so that I can adjust it's placement or width, at which it places the arrow in my well construction portion of the log. Any ideas/suggestions? Thanks! Kristin
The well pointer width is set in report design. Open your report in report design you will see a line vs depth entity similar to below. double click on the entity and goto the column width expression. You will need to modify it accordingly. This is just an example so your files may look different. You would need to add the new variables into the expression. If you have modified the original well column widths then it gets a little more complicated. If you want to send me your files click on my name and email me your library and project and I can give you more detailed instructions based on your customized files
