Hi all,
I've stuck on a trouble with making dynamic Maximum Value, I tried to use <<REPORT VAR.FINAL DEPTH>> at maximum value cell and set <<USER SYSTEM DATA.DG RPT CONFIG DEPTH LOG PAGE>> at FINAL DEPTH cell which coded as below:
<<FirstData(_ <<Sql(_ select [REPORT_CONFIGURATION].[Depth_Log_Page] _ from [REPORT_CONFIGURATION] _ where [REPORT_CONFIGURATION].[Report_Name] = '<<ReportID>>' _ and [REPORT_CONFIGURATION].[PointID] = '<<PointID>>'_ )>>_,_ <<get(Default)>>_)>>
But the output graph still return the different maximum value for the graph. i.e.
Hole ID BH1 BH2
Depth 133m 150m
Expected graph depth 133m 150m
Graph showing depth 120m 160m
Hope that someone can help me on this problem, thank you very much.
BTA
Phil WadeDatgelBentley Channel Partner and Developer PartnerE: phil.wade@datgel.com | T: +61 2 8202 8600 & +65 6631 9780
Get the most out of gINT with Datgel Tools.
