GINT Civil Tools - Adding a borehole symbolisation rule
So I'm trying to represent different borehole types with a different symbol cells. There are 2800 boreholes in total.. I believe I'm doing everything correctly but all the boreholes are being plotted by the "Default" point type. Even though the Property and the value is specified in the symbology tab. Is there something I am missing?
I've attached the data connectivity and the borehole properties.
The symbol should change the for the "type of activity". Ie. "CP+RC".
Parents Reply
  • No still doesn't work. I have tried:
    - Starts with
    - Contains
    - Equals CP
    - Equals 'CP'
    - Changing the cell to a cell that is delivered with ORD
    - Plotting via the "Property" instead of default
    But still plots all boreholes to the default point cell
    I do however, get this warning when query all. Do you think the number of boreholes is an issue? It seems to process the points ok after about 60 seconds, but the cell doesn't plot to different symbols.
    I tried an advance query to reduce the sample size but still doesn't work.
