<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Multiple fields in Column Text Vs. Depth</title><link>https://communities.bentley.com/products/geotechnical1/f/geotechnical-announcements-forum/152432/multiple-fields-in-column-text-vs-depth</link><description>I want to create a lab test text column on my log report. The results in that column could be water content, fines, LL/PL, or UCS. In the column text vs. depth property I can only do 2 of these 4. I could create a 2nd column text vs depth entity, but</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Multiple fields in Column Text Vs. Depth</title><link>https://communities.bentley.com/thread/456276?ContentTypeID=1</link><pubDate>Tue, 17 Apr 2018 22:16:33 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f1b410f0-00fb-497e-affa-84f463065525</guid><dc:creator>Jesse Greenwald</dc:creator><description>&lt;p&gt;Hi Monique,&lt;/p&gt;
&lt;p&gt;You can do this all in one column using&amp;nbsp;a&amp;nbsp;&amp;quot;Component Description&amp;quot; Library Table and Function.&lt;/p&gt;
&lt;p&gt;Please see Help&amp;gt;Index&amp;gt;Component Descriptions for a detailed overview of how to implement this. In particular, look at the &amp;quot;Setting up Component Structures&amp;quot; article and the &amp;quot;Mixing Tables in the Library Tables&amp;quot; article.&lt;/p&gt;
&lt;p&gt;There is also good example in the&lt;a href="/products/geotechnical1/w/wiki/5303/gint-standard-reports"&gt;&lt;em&gt; gINT Standard US Lab&lt;/em&gt; files&lt;/a&gt;&amp;nbsp;in the &lt;em&gt;GENERAL BH / TP / WELL&lt;/em&gt; report. Look at the &amp;quot;Tests and Remarks&amp;quot; column, which has these Properties:&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/343483/2018_2D00_04_2D00_17_5F00_14_2D00_42_2D00_12.png" /&gt;&lt;/p&gt;
&lt;p&gt;You would need to set up the Text &amp;amp; Depth Expressions slightly different.&lt;/p&gt;
&lt;p&gt;For the Text Expression, you would not need to include the ListBuildSepTrim() Function or the reference to the Remarks table.&lt;/p&gt;
&lt;p&gt;For the Depth Expression, you could just use &amp;lt;&amp;lt;Depth&amp;gt;&amp;gt; to include data for tests not at the sample top depth.&lt;/p&gt;
&lt;p&gt;So, your column properties would be like this:&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/343483/pastedimage1524001674966v1.png" /&gt;&lt;/p&gt;
&lt;p&gt;You&amp;#39;d also have to set up the &amp;quot;TESTS&amp;quot; Component Description Library Table. You can create the TESTS table in Data Design&amp;gt;Library Tables&amp;nbsp;under Tables&amp;gt;New Component Description Table. When prompted, you can select all the &amp;quot;Fields to Merge&amp;quot;, although you probably won&amp;#39;t use them all.&lt;/p&gt;
&lt;p&gt;Then you have to go to Data Design&amp;gt;Library Data to set up the formatting for each component in your Test column. Again, see the TESTS table in &lt;em&gt;gINT STandard US Lab.glb&lt;/em&gt; for a good example, as well as the Help articles:&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/343483/pastedimage1524002557943v2.png" /&gt;&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Please let me know if anything doesn&amp;#39;t work or is unclear&lt;/p&gt;
&lt;p&gt;Jesse&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
