Hi
Please see below snapshot. I couldn’t find the data template to start the project. kindly do the needful
Hello Vinay,
Looks like you did not select to install the standard dataset files during the installation that come with the gINT. That could be why the data template folder is empty. You can download these files from this link below. The zip file contains project (.gpj), library (.glb) and the data template (.gdt). Once you download and unzip this file, you can put the files in the same path you have in the picture. Just put project file in the project folder, library file in the library folder and data template in the data template folder.
Hi Aparna,
Thanks. Now it is working. Can you please share a video generating new logs in report design.
Vinay,
Creating new log reports could be complicated based on the data that needs to be referred in. Our standard library has a variety of templates based on industry standards that show a multiple data combinations on a log. Editing an existing templates to one's need most often becomes easier of a task rather than creating something from scratch. Creating a log report from scratch would require a good internal knowledge and experience of 'how-to' in gINT.
We have a lot of resources on our Bentley communities that can help you get started with editing reports.
