We have been upsizing data into SQL for the past year and are starting to accumulate quite a bit of data. Close to 4000 boring points to be exact. I understand the full process to Upsize and map all this geo-spatially but now here is the question. What does Bentley plan on doing to assist the end user to remove a record? I have found that I can perform this in SQL Management Studio fine but is there a plan to create a function to remove record in gINT in the SQL state? Currently if you try to remove the record in the SQL gINT it prompts you to contact the DBA.
Any easier solutions would be great.
Are you removing a borehole record or a project?
Kathleen,
The data that I would like to be able to remove is the Parent project record. I am able to remove the child Borings. I did find that a short SQL script did the job though.
Answer Verified By: Kathleen Holcomb
Hi Todd,
Yes, for the present, that is the only way to remove a project record.
