We export part of our reports to gINT Drawings so we can manually add some lines (for example draw the fracture state of the rock in UCS).
gINT allow for Export => PDF. However, this only exports the page that is currently being edited.
In our case we want to output all the pages, and hence opt for Print => Adobe PDF printer.
When doing so, we get the following error. We have tried several PDF Output programs (Cute PDF, etc...) and we still experience the same error.
Problem signature:
Problem Event Name: APPCRASH Application Name: gint8.exe Application Version: 8.2.0.4 Application Timestamp: 4a11db85 Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.18247 Fault Module Timestamp: 521ea91c Exception Code: c0000005 Exception Offset: 00052d37 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: e643 Additional Information 2: e643eb9d3f5275669e237f670dd06960 Additional Information 3: 34e5 Additional Information 4: 34e5b0b3f64ad8cbf9bfaaa30ccaa6a4
Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
Hello Aly,
Sorry, there is a bug that is only allowing the first page of a drawing to be exported to PDF. I created a service request so that we can let you know when this is fixed. I'll email you from the service request.
Unfortunately, printing to PDF is often problematic. gINT does very complex things at print time. Using our PDF driver (by exporting to PDF) is the only reliable way of creating a PDF.
Answer Verified By: Ali Abdelaziz Ali
